Configure SLPP Guard
Configure SLPP Guard on MLT and LAG ports to provide additional network loop protection.
SLPP Guard is disabled by default.
 - Select SLPP.
 - Select the SLPP Guard tab.
 - In the port row, double-click the cell in the Enabled column.
 - Select true from the drop-down list to enable SLPP Guard, or false to disable SLPP Guard for the port.
 - Optional: In the port row, double-click the cell in the Timeout column.
 - Optional: Type a value in the Timeout field.
 - Select Apply.
 - On the toolbar, select Refresh to update the work area data display.
SLPP Guard Field Descriptions
Use the data in the following table to use the SLPP Guard tab.
 Name  |
 Description  |
 IfIndex  |
 Specifies the port on which to configure SLPP Guard.  |
 Enable  |
 Enables (true) or disables (false) SLPP Guard for the port. The default is disabled.  |
 Timeout  |
 Specifies the time period, in seconds, for which SLPP Guard disables the port. After the timeout period expires, the switch re-enables the port. The timeout value can be 0 or a value ranging from 10 to 65535. With a value of 0, the port remains disabled until it is manually re-enabled. The default Timeout value is 60 seconds.  |
 Status  |
 Displays the SLPP Guard status for the port.  |
 TimerCount  |
 Indicates the time, in seconds, that elapses after SLPP Guard disables a port. When the TimerCount value equals the Timeout value, the switch re-enables the port.  |
                                                   GuardOrigin  |
                                                   Specifies the origin of SLPP Guard configuration on the port. The supported values are:
